I run a script creating retaining wall as follows, which is similar to Plaxis training video. However there was a error as in the picture below. Could you help me to fix this? Thank you
CODE:
# PLAXIS boilerplatefrom plxscripting.easy import new_server, get_equivalent
localport = 10000pw = r'G<12345678's_i, g_i = new_server('localhost', localport, password = pw)def create_retaining_wall(wall_length, excavationwidth): """ Generate the plate element based on the wall length :param wall_length: length of the wall :return: line object with plate and interface """ start_x = excavationwidth surface_elevation = 30 start_y = surface_elevation newitems = g_i.line(start_x, start_y, start_x, start_y - wall_length) # newitems is a list, containing the newly created points and the line line = newitems[-1] # define plate and interfaces on this line g_i.plate(line) g_i.posinterface(line) g_i.neginterface(line) # also set the material line.Plate.Material = g_i.Dwall return line def run_parameter_case(wall_length, tiebackdepths, tieback_length, bonded_length, tieback_angle, tieback_prestress, excavationwidth, excavationdepth):
# Load a basic model with soil layers, soil datasets and structural datasets basicmodel = r'H:\1. DATA\document\PLAXIS\Bentley training\Basic parametric model1.p2dx' s_i.open(basicmodel) # Create the wall, based on length wall_line = create_retaining_wall(wall_length, excavationwidth)# Create the excavation volumes (useful for easy deactivation)# Create the tiebacks# Generate the mesh# Construct phases# Calculation# Retrieve Output results: max hor defection, maximum bending moment# settlements at distance 1, 10, 30 m
#start parameterswall_length = 26excavationwidth = 20excavationdepth = 18tiebackdepths = [3, 7, 11, 14]tieback_length = 16bonded_length = 4tieback_angle = 25tieback_prestress = 800
ERROR
>C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1 Update 1\python\pythonw.exe -u "excavation_tieback.py"Traceback (most recent call last): File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1 Update 1\python\lib\site-packages\plxscripting\plxproxy.py", line 177, in __getattr__ return self._getattr(attr_name) File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1 Update 1\python\lib\site-packages\plxscripting\plxproxy.py", line 114, in _getattr raise AttributeError("Requested attribute '{}' is not present".format(attr_name))AttributeError: Requested attribute 'line' is not present
During handling of the above exception, another exception occurred:
Traceback (most recent call last): File "excavation_tieback.py", line 58, in <module> excavationwidth, excavationdepth) File "excavation_tieback.py", line 36, in run_parameter_case wall_line = create_retaining_wall(wall_length, excavationwidth) File "excavation_tieback.py", line 17, in create_retaining_wall newitems = g_i.line(start_x, start_y, start_x, start_y - wall_length) File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1 Update 1\python\lib\site-packages\plxscripting\plxproxy.py", line 180, in __getattr__ return self._getattr(attr_name) File "C:\ProgramData\Bentley\Geotechnical\PLAXIS Python Distribution V1 Update 1\python\lib\site-packages\plxscripting\plxproxy.py", line 114, in _getattr raise AttributeError("Requested attribute '{}' is not present".format(attr_name))AttributeError: Requested attribute 'line' is not present>Exit code: 1
Screenshot
Dear Nam,
You have posted the same question here:
communities.bentley.com/.../713911
