How to determine soil failure in Plaxis
Hi everyone,
I am simulating an embankment of 4m high on a soft soil layer (cohesion = 1kPa, Friction = 18) using the consolidation calculation type and soft soil model. At first, I thought that the model would notify soil body collapse. However, it did not, and then I added a safety calculation after the consolidation phase and got a safety factor (FS) of 1.009. After that, I reduced the friction of soft soil to 14 then rerun but the result was almost the same, FS ~ 1.009. It seems that Plaxis never notify the failure or soil body collapse no matter the softness of soil in consolidation calculation type. Do I understand correctly and is any method to get the failure notification from Plaxis in this case? I attached a brief description for your information.
Thank you
Soil failure.pptx
