Hi, the option for consolidation analysis does not seem available in the calculation phases, only plastic and phi-c reduction. Not sure why this is?
I am trying to model heave over time due to an excavation in clay.
thanks
Hi Howard,
Consolidation is a time-dependent analysis and thus available only to "Advanced" and "Ultimate" license tiers. You can read more in the link below:https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/42955/plaxis-connect-edition-licenses
Please check which license you are using by clicking on the "About" option under the Help menu.
Answer Verified By: Howard Roark
