Hi guys,
I tried to use Python scripts to select a node and want to retract the Utot of this node for all steps and phases.
Here is how I selected the node
output_port = g_i.selectmeshpoints()s_o, g_o = new_server('localhost', output_port, password='123456789')g_o.addcurvepoint('node',(0,0),(1,0))g_o.update()
And then I used the code posted in the forum to retract the Utot
u.append(g_o.getcurveresults(g_o.CurvePoints.Nodes[0], step, g_o.ResultTypes.Soil.Utot))
But I got error message
PlxScriptingError: Unsuccessful command:not foundThere are missing result(s). Either the project isn't calculated or the result type isn't available in this phase or step.
Wondering how to fix this?
Thanks in advance!
Dear Xuyan Liu,
At the following line:u.append(g_o.getcurveresults(g_o.CurvePoints.Nodes[0], step, g_o.ResultTypes.Soil.Utot))
you include the "step". That means that possibly you try to retrieve the results for all steps, while they have no data as the error describes.
Without checking the model, my first guess would be about whether that specific node at (0, 0) is active in all steps or does it become active at some point in your calculation?
That can explain why for instance, why in Step_0 or Step_1, there is no deformation to show for that node.
