Steady state flow analysis through a earthrn embankment in plaxis 2D advanced
Hello
I'm doing a steady state seepage analysis of water seepage in Plaxis 2D advanced edition.
Could anyone kindly help me out?
Thank you
Parents Reply
  • Dear Sreerag,
    The tutorial uses the PLAXIS 2d Ultimate license as the analysis uses the Fully coupled flow-deformation calculation type. However, with the PLAXIS 2D Advanced you can still do a Steady-state groundwater flow analysis, which is also explained in the example.
    I am not sure what you mean that you cannot define the Phreatic line.
    Have you drawn one in the Flow conditions and it does not appear?
    Have you applied a groundwater flow boundary conditions on the model boundaries as Head and do not see it being applied?
    I would advise following the on-demand materials as you can find the solution to your problem.
    If not, feel free to send us a service request to assist you in detail: https://apps.bentley.com/srmanager/ProductSupport
    Answer Verified By: Sreerag Chentrathodi Sreekumar
