Hey,
I am trying to calculate pullout capacity of a suction caisson for my thesis at the end of Aug.
I am new at using Plaxis (less than a month) and I've found a tutorial on plaxis website. I have followed it through and got results. However, the plaxis tutorial did not consider the thickness of the pile so I added an inner surface with a smaller radius (3.92 m).
Tried to generate mesh and this error came up
Meshing failed with the following error:
Fatal: Could not generate mesh.Fatal: Invalid element(s) found. Related geometries: BoreholeVolume_1_1. Inspect the geometry locally.Warning: 591 EMR warnings have been detected. The 12 most severe are listed, the remaining 579 are not shown.Warning: # 1/517 of small 3D proximity: detected size 7.97e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_1_1, Surface_4_1. Inspect the geometry locally.Warning: # 2/517 of small 3D proximity: detected size 7.97e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_1_1, Surface_4_1. Inspect the geometry locally.Warning: # 3/517 of small 3D proximity: detected size 7.97e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_1_1, Surface_4_1. Inspect the geometry locally.Warning: # 4/517 of small 3D proximity: detected size 7.97e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_1_1, Surface_4_1. Inspect the geometry locally.Warning: # 5/517 of small 3D proximity: detected size 7.97e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_1_1, Surface_4_1. Inspect the geometry locally.Warning: # 1/72 of small in-surface proximity: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_3_1. Inspect the geometry locally.Warning: # 2/72 of small in-surface proximity: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_3_1. Inspect the geometry locally.Warning: # 3/72 of small in-surface proximity: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_3_1. Inspect the geometry locally.Warning: # 4/72 of small in-surface proximity: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_3_1. Inspect the geometry locally.Warning: # 5/72 of small in-surface proximity: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_2_2. Inspect the geometry locally.Warning: # 1/2 of small edges: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_2_2, Surface_3_1. Inspect the geometry locally.Warning: # 2/2 of small edges: detected size 8.00e-02; this is 1.47e+01 times smaller than minimum targeted element size. Related geometries: Surface_2_2, Surface_3_1. Inspect the geometry locally.0322> _save "\\adf\storage\j\f\jsf622\Documents\MSc Project\Plaxis 3D\1st try\winged_thick.p3d"
I have also tried to add wings to the caisson and a similar error came up.
In addition, how do I add load to the structure at different angles (0, 30, 45, 60, 80, and 90) ?
I look forward for the feedback
Does the gap between the inner circle and the outer circle filled automatically or I have to create a top surface for it? also, it is quite impossible to create a continuous structure to avoid gaps
Hello again,
No, you would need to create a surface as Piyush mentions.
Note that my comment was not for actual gaps that exist in reality but for inaccuracies in geometry, e.g., something that should have been snapped but by drawing by hand it is not properly snapped.
This is my polycurve design. It is still giving errors
Dear Jozanga,
I would not expect this to cause problems, so in order to be able to understand what is going on, I would like to check the whole project.
Please submit a service request. Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
