Dear
Could there be any possibility to define 2 different precipitation (rainfall) for two different zones in the model? Could I distinguish two different zones in the model and define different precipitation for them separately?
Thanks for your response
I look forward to hearing from you
Amir Farshadfar
Dear Amir,
Yes, that is possible.
But to do so, don't use the automatic Model condition called "precipitation" because that will indeed be the same for the entire model. Instead, manually define "Surface groundwater flow boundary conditions" on both zones and set their behaviour to "Infiltration". You can now create multiple flow functions and assign different flow functions to different infiltration boundaries.
With kind regards,
Dennis Waterman
