What is the Python code to calculate the reaction Fy in a 2D model? I could not find it in the reference.
Hello Sarah,
I will explain how you can find it.
Practically you see this value in the Phases window, right? So, that is part of the Phases object.
Therefore, a first step would be to do an
echo Phase_1
This will give you all the information for that phase. If you search you will find the force y you are looking for.
With this you can find that it belongs to the:
Phase_1.Reached
So, another time you can run an echo on that and see the properties that belong where. And there is where you will find the property name.
