Plastic Points Cannot be Turned Off
Hi All
I am viewing plaxis 3d results, specifically plastic points, and there are many points that just do not seem to be controlled by any filter. Even if i turn off all the materials and geometry, they still show in the plot. I need to understand which materials they correspond to. Also i want to be able to turn them off (after i verify their material) because they are polluting the plots.
Did anyone encounter this and do you know of a solution for this?
Thank you for your help!
