I'm working on an automated model for designing simple retaining walls in Plaxis.
The way the code works, is that it gradually increases the length of the retaining wall in a loop until a required FoS is achieved.
However, if the length of the wall is too small, the model stops running as the "soil body collapses", in which case, I want the python code to increase the length of the wall automatically instead of completely stopping the code.
Is there any way that I can handle this error in Python without having to manually increase the wall length and trying again? something like this:
If [soil body collapsed]:
wallLength = wallLength + 0.5
continue
Cheers,
Hey just for the people having the same issue in the future, I solved it using a simple try and except command in Plaxis. Something like this:
try: g_i.calculate() localhostport_o = g_i.view(g_i.Phases[-1]) s_o, g_o = new_server('localhost', localhostport_o, password=s_i.connection._password) staticFoS = g_o.Phases[4].Reached.SumMsf except: break
