I am using plate element in PLAXIS 2D model . is it necessary to give the value of weight of plate in general properties tab?
Hi Shailja,
If you want to account for the weight of the plate, then you should also specify its unit weight (w). Otherwise, if left blank, the plate is considered weightless.
Answer Verified By: Shailja Joshi
are you sure there is no problem in the results
Dear Dhyaa,
This is a question that only the geotechnical engineer who designs the project can answer.
I would advise you to carefully inspect your Output results after running the analysis and evaluate whether this approach is acceptable.
Ok, dear Stefanon, I will do that, thank you for your advise.
