<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Lateral resistance of embedded beams</title><link>https://communities.bentley.com/products/geotech-analysis/f/forum/234774/lateral-resistance-of-embedded-beams</link><description>Hello,
 I have a question regarding the applicability of lateral resistance in piles. In many research works, I have seen it mentioned that &amp;quot; PLAXIS does not account for lateral resistance/slide for embedded beams&amp;quot;. But in the software, I see I can</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Lateral resistance of embedded beams</title><link>https://communities.bentley.com/thread/729267?ContentTypeID=1</link><pubDate>Wed, 31 Aug 2022 13:59:54 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:e849a6ea-83d3-4016-8072-979041ed6d07</guid><dc:creator>Faisal Ahmed</dc:creator><description>&lt;p&gt;Hello Stefanos,&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Thank you very much for your reply. Can you please suggest&amp;nbsp;what is the best rule to calculate lateral resistance of pile by hand/graph? Also, can you please share any work that employs an embedded beam for lateral resistance and is validated with actual work?&lt;/p&gt;
&lt;p&gt;&lt;/p&gt;
&lt;p&gt;Best regards,&lt;/p&gt;
&lt;p&gt;Faisal&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item><item><title>RE: Lateral resistance of embedded beams</title><link>https://communities.bentley.com/thread/729229?ContentTypeID=1</link><pubDate>Wed, 31 Aug 2022 11:03:13 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:b6626b9d-6da5-4f55-a36a-91fb7be04240</guid><dc:creator>Stefanos Papavasileiou</dc:creator><description>&lt;p&gt;Dear Faisal,&lt;/p&gt;
&lt;p&gt;In the last years, there have been improvements to the behaviour of the embedded beam element in PLAXIS. Probably the research you check is still considering old versions in which the lateral resistance was still considered unlimited.&lt;/p&gt;
&lt;p&gt;In the newer versions of PLAXIS there are options to define the lateral resistance as Unlimited (default and legacy behaviour), Line and Multi-linear as seen below.&lt;/p&gt;
&lt;p&gt;&lt;img src="/resized-image/__size/320x240/__key/communityserver-discussions-components-files/343671/pastedimage1661943860385v1.png" alt=" " /&gt;&lt;/p&gt;
&lt;p&gt;For more information please check our Reference manual.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
