How to make a 2d array for volume element using python scripting in PLAXIS 3D?
Dear Rituraj Singh Sujawat,
I am not sure what you mean by your question.
Do you ask how to use the array command in PLAXIS 3D?
Or do you need help creating copies of a volume structure with Python commands?
For the first, the array command is also explained in our Scripting reference: https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45447/scripting-reference-and-how-to-use-it
Practically you would array the whole volume element and then provide the parameters for the command.
In case you want to "implement" the array with Python, I guess you would need a function that creates the volume and each time run different parameters when it comes to the location, size, etc.
