I have a question about the plate properties in PLAXIS. In 2D, there is a specific input as "unit weight (w)" and in 3D, there is another specific unit weight as " unit weight (gamma)". I know how to get the unit weight for PLAXIS 3D but for 2D, I came to know the unit weight of the soil has to be deducted from the unit weight of the plate material. I could not find any good reference about why it has to be done like this in PLAXIS 2D and so I seek your help to help me resolve this confusion. Please help.
Thank you
In case of tunnel modelling, unit weight of soil should be subtracted from the unit weight of concrete?
You just need to think what you are aiming. The link Vasileios is really good. For some cases where the bending moments are more important, I use concrete unit weight x plate thickness for 2D. However, this creates higher pressure in the soil, so settlements are higher. If settlements are important, you go for correct stress in soil, so you need to reduce the soil unit weight.
Not an easy task always.
ok sure,thanks
