I am trying to perform soil test using the parameters of modified cam clay. But one of the parameter 'lambda' is not recognized by PLAXIS SOIL TEST if run through python. Please find source code of it:
from plxscripting.easy import * s_t, g_t = new_server('localhost', 10101, password = 'Parik@1410') g_t.Triaxial.Behaviour = "Undrained" g_t.Triaxial.CellPressure = 100 g_t.Material.lambda = 0.09 g_t.Material.kappa = 0.08 g_t.Material.nu = 0.25 g_t.Material.einit = 0.4 g_t.Material.M = 1.2 g_t.calculate(g_t.Triaxial) print(g_t.Material.echo())
Error
I am using echo function also to find the variable and it is showing same name "lambda" in output as shown below.
SoilMat named "Material" Comments: "Clay1" MaterialName: "Clay1" Colour: 11242654 MaterialNumber: 0 SoilModel: Modified Cam-Clay (8) UserDefinedIndex: 0 DrainageType: Undrained (A) (1) DilatancyCutOff: False UndrainedBehaviour: Standard (0) InterfaceStrength: Rigid (0) InterfaceStiffness: Standard (0) ConsiderGapClosure: True K0PrimaryIsK0Secondary: True K0Determination: Automatic (1) CrossPermeability: Impermeable (0) Gref: 1050 kN/m² cref: 5 kN/m² phi: 30 ° psi: 0 ° verticalref: 0 m cinc: 0 kN/m²/m K0: 0 gammaUnsat: 15.5 kN/m³ gammaSat: 17.5 kN/m³ perm_primary_horizontal_axis: 0 m/day perm_vertical_axis: 0 m/day Rinter: 1 perm_secondary_horizontal_axis: 0 m/day TensileStrength: 0 kN/m² UDPower: 0 verticalinc: 0 Ginc: 0 kN/m²/m ninit: 0.285714285714286 nmin: 0 nmax: 0.999 gammaPore: 0 RayleighAlpha: 0 RayleighBeta: 0 ck: 1E15 UDPRef: 0 kN/m² einit: 0.4 emin: 0 emax: 998.999999999999 Dinter: 0 K0Primary: 1.61743558611769 K0Secondary: 1.61743558611769 OCR: 4.018 POP: 0 kN/m² SoilRatioSmall: 10 % SoilRatioMedium: 13 % SoilRatioLarge: 77 % PsiUnsat: 10000 m Sres: 0.0620347394540943 Ssat: 1 Gn: 1.3774 Ga: 3.83 1/m Gl: 1.25 PsiK: -1.06 m PsiS: -2.37 m HydraulicModel: 1 FlowDataModel: 0 DrainageConductivity1: 0 m³/day/m DrainageConductivity2: 0 m³/day/m InterfaceKn: 0 kN/m³ InterfaceKs: 0 kN/m³ DefaultValuesAdvanced: True nu: 0.25 DataSetFlow: Standard (0) SoilTypeFlow: Coarse (0) M50: 0 - 50 (0) UseDefaultsFlow: None (0) TablePsiPermSat: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0] SplinePsiPerm: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0] SplinePsiSat: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0] lambdaModified: 0.428571428571428 kappaModified: 0.0571428571428571 K0nc: 0.652920753140292 lambda: 0.6 kappa: 0.08 LambdaKappa: 7.5 M: 1.2 powerm: 1 Pref: 100 kN/m²
Help me with this query
Dear Rituraj,
That is indeed an issue as lambda is a reserved word in Python and it conflicts with Modified Cam-Clay's lambda material parameter. A quick search online would give you information on the lambda function.
Until we fix this issue, you can use the following workaround as a Python command:
setattr(g_t.Material, "lambda", 0.09)
Thankyou Stefanos, that was really helpful. Your team is awesome
I am facing same problem with PLAXIS 3D input also while assigning material property. Its not considering lambda as material parameter. Can you please help me with the script for this operation.
Hello Rituraj,
The solution I gave you should also work in PLAXIS 3D, as this shared code. At least it works in my case:
Hi Stefanos,
Sorry to trouble you. But I am getting this error while assigning the parameter.
