I have one extensive model and two PC with different CPU setup.
Is there a easy way to track the runtime of the model calulation like a log file.
I want to compare the PC performance.
Thank you.
Dear Falko,
We do have some debug files, whose purpose is internal but you can use them for this case, too.
Every project stores the files debug.dXX, in which the XX is the phase number. In these files, you can scroll all the way to the end and check the CPU time and Wall clock time. The wall clock is real-world time, and CPU time depends on the number of cores used in the calculation (PLAXIS by default uses all your PC has).
Answer Verified By: Falko Schmidt
thank You!
