Extract results over a chosen interface Python
I'm trying to write a python script that will extract stress and displacement results from all nodes on a single chosen interface, but am having some trouble with getting results for the interface element, i've tried variations on the code below, but get the error as shown:
Code:
stress_results = g_o.getresults(phase,g_o.ResultTypes.Interface.InterfaceTotalNormalStress,'node')
(also not working: g_o.getresults(interface,phase,g_o.ResultTypes.Interface.InterfaceTotalNormalStress,'node')  ((the structure of which works fine for extracting beam / embedded beam results)
Error (in PLAXIS):
!!!!> getresults 8 ResultTypes.Interface.InterfaceTotalNormalStress "node"
Invalid parameters. Make sure that the specified parameters match the ones that are expected.
I know the above (when working) will get me node results for every interface in the model. Would there be a way to instruct it to only extract results from an interface with a certain reference?
As always, any help would be very much appreciated!
Kind regards
Maddie
Parents Reply Children
