<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Embedded Beam Row Permeability &amp;amp; Skin Friction</title><link>https://communities.bentley.com/products/geotech-analysis/f/forum/236021/embedded-beam-row-permeability-skin-friction</link><description>Hello,
 I have a couple of questions regarding the embedded beam row:
 How can I make an embedded beam row impermeable (i.e. so water has to flow around the base of the wall)?
 When specifying the skin friction in the input program I am assuming</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Embedded Beam Row Permeability &amp; Skin Friction</title><link>https://communities.bentley.com/thread/734661?ContentTypeID=1</link><pubDate>Fri, 30 Sep 2022 12:44:46 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:0d869855-65f9-471e-84c4-c2c27f545764</guid><dc:creator>Dennis Waterman</dc:creator><description>&lt;p&gt;Dear Charlie,&lt;/p&gt;
&lt;p&gt;1) You can&amp;#39;t. An embedded beam row is not a wall, it is a row of individual line elements like a row of piles or a row of anchors. Hence, water will always be able to flow in between through the soil that is inbetween the piles. If you want to model a wall, you should use a plate element.&lt;/p&gt;
&lt;p&gt;2) That is correct.&lt;/p&gt;
&lt;p&gt;3) Note that in Output it shows the skin friction per meter length per meter out of plane whereas in input you specify the max skin friction for a single element. Hence, the results in output should be multiplied with the spacing to compare them with the input values.&lt;/p&gt;
&lt;p&gt;With kind regards,&lt;/p&gt;
&lt;p&gt;Dennis Waterman&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
