Hi, PLAXIS team,
I'm struggling to understand what the upper limit for material stiffness, i.e. E50 in Hardening Soil Model is? I am exploring different material models for a very low to low strength Siltstone (UCS = 1MPa, E50 = 300MPa) and I was thinking to consider modelling this with HS model, as unloading characteristics of this material is of my great interest. I have run a SoilTest triaxial simulation for this low strength material but the results would not match (or not even close to) the available lab test data, i.e. E50 = 200MPa. Needless to say, the Stress-Strain curve is almost linear elastic - perfectly plastic, rather than elastoplastic, which I suspect that it's due to the high shear stiffness.
It would be great to hear your thoughts.
Many thanks,Farzam
Hi Dennis,
This was very educative. Thanks for your time to explain it in detail. I always learn something new from you.
Warm regards,
Farzam
