Hi folks. how do I search with a defined circular slip surface in Plaxis LE API?
There is no method for defining a single circular slip surface via the API, but you could simulate one by using FullySpecifiedSearch, and choosing enough linear segments to approach a circle. You can compute this set of lines pretty easily with some Python code.
Thank you very much Faseel.
