How does dynamic multiplier work? I read about in the manual but I see results in my analysis that don't correspond to my dynamic load set up. Let's say I set up dynamic load as qy,start,ref= - 8000lbf/ft/ft, and then I set up the Dynamic Multiplier as in table below (without static load):
Then, if I set up "Dynamic time" as 0.9s (in the Phase set up), will this process be repeated (5 times because 0.18*5=0.9)?
Also, will the load be applied as:
Thank you!
Dear Antonio,
The calculation will not be repeated 5 times. In the table you specify the time, hence after t=0.18 there is no more data and it will keep using the last known load data, which is zero.
With kind regards,
Dennis Waterman
I have same question about this , I want to confirm the load result which the poster say is correct or wrong?
thank you!
Dear YY Ko,
The load results as given by OP is correct. This is how it works : applied load = (input load) * multiplier
thank you very much ! You really help me a lot !
