Dear Stefanos and Team,
I am using Plaxis 2D V21. I am currently trying to re-do Tutorial 7 (Excav. of an NATM Tunnel) through Python remote scripting. I would like to perform the "extendtosymmetryaxis" and "symmetricclose" command through python. The command line looks like the following:
Normally, I would expect the python script to look like:
g_i.extendtosymmetryaxis(g_i.Tunnel_1.CrossSection) g_i.symmetricclose(g_i.Tunnel_1.CrossSection)
However, I got an "AttributeError: Requested attribute 'extendtosymmetryaxis' is not present" error. I also can't find the commands in scripting or command reference (from the Help menu). Is there a way to do this through remote scripting? or is there a reference/manual that I overlook?
Thank you very much for your time and attention.
Kind regards,
M. Rayyan
Dear Stefanos,
Nevermind, I found the way. Turns out the python scripting is:
g_i.Tunnel_1.CrossSection.extendtosymmetryaxis() g_i.Tunnel_1.CrossSection.symmetricclose()
Answer Verified By: Muhammad Rayyan
Correct!
