Can Plaxis 3D be set up to run on a cloud computing virtual machine (such as Microsoft Azure)? And would there be any significant calculation speed increase from having it run on a VM set up that can have up to 96 vCPUs and 1TB of RAM but less processing speed per CPU (max 3.5 Ghz), versus just a powerful in-house workstation (such as 4-core 4.1 GHz processor and 64 Gb Ram)?
Dear Cory,
PLAXIS is implemented and tested to work on native Windows OS in a physical PC. However, it should be possible to be used in a virtual machine.
Note that virtual machine do apply special settings when it comes to visualisation (to make the remote communication faster). But running a calculation on a virtual machine should be fine. Be aware that since we do not test and support running PLAXIS on a virtual machine any issues that may arise need to be handled via a Service Request: https://apps.bentley.com/srmanager/ProductSupport
With regards to computer specifications, all our recommendations we provide are based on single desktop computers with a natively running Windows 64-bit environment (Windows 10/11), since this is what we design the software for and run all our tests on. The system requirements are mentioned here: https://communities.bentley.com/products/geotech-analysis/w/plaxis-soilvision-wiki/45417/system-requirements---plaxis
To get quick operations in the program:
If you need to make a choice between more CPU cores or faster CPU cores, I would go for the faster cores if your main concern is the PLAXIS calculation speed. We have seen once you have at least quad-core processors, you benefit more from a faster CPU than from more cores.
PLAXIS does not enforce limits on the number of items in a 3D calculation, but of course, the more elements you have, the more memory the program needs, and then you can run into hardware limitations.
Of course, this is the experience we have with the current program.
See more details here:
Plaxis does offer certain courses. However, they are prohibitively expensive (€200 for online and €2000 for in-person courses). If possible, arrange for your business to organize a training session, or perhaps someone in your firm has already attended one from www.networklondon.co.uk/. If you can get your hands on them, the course notes and slides are quite beneficial! Another possibility is to experiment with different Geotech FEA programs. Because Adonis is a free, open-source FEA, it may be beneficial to master the fundamental ideas of meshing, constructing geometries, and applying necessary parameters.
When it comes to the calculation speed increase from running on a VM versus a powerful in-house workstation, it depends on the complexity of the analysis. Generally speaking, the more cores and RAM available, the faster the analysis can be completed. In this case, the VM with up to 96 vCPUs and 1 TB of RAM will be able to process more data than the in-house workstation with 4-cores 4.1 GHz processor and 64 GB RAM. However, the processing speed per CPU can be slower on the VM (max 3.5GHz) than the in-house workstation, so the calculation speed may be slower overall. For more professional details, I would recommend to reach out to a cloud consultancy. The guys from there will definitely help you.
Adonis is only for 2D analyses. Most of the challenges in heavy numerical modelling come from 3D modelling. Still, the application of cloud computing is necessary.
