Divergence between model in interface and api - PLAXIS LE
Hi folks,
I'm creating a model in the script and I wanted the same results from interface. I thought it might be a difference in the convergence settings, but it's not. The FOS is the same in both models, but the position of the slip surface is different. Could someone help me to verify why the script's slip surface is different from the interface?
Best regards,
Mariele
