Dear Plaxis community
I have a question about the interfaces around corners. Everytime that I model a retaining wall as a plate I get some high peaks of stresses. I was reading the manual and got into the part where I have to "refine" the interface to get better results.
My question is, as the image below, is this the right way to model the corner of the structure?
Hi João,
I would say that your approach is correct.
Although it is not always necessary, it is a good modelling practice to prevent stress oscillations by specifying additional interface elements inside the soil body. However, remember that these (extended) elements should not introduce an unrealistic weakness in the soil.
For example, when using Rinter < 1 for these interface elements, an unrealistic strength reduction is introduced in the ground, which may lead to unrealistic soil behaviour or even failure. Therefore, special attention should be paid to these interface elements’ properties. For instance, it is advised to create a separate data set with Rinter = 1 and to assign this data set only to these particular interfaces (extended beyond the plates).
Generally, the subject of stress oscillations is complex and can be attributed to different reasons, such as the density of the mesh, the smoothing of results, etc.
Answer Verified By: João Victor Andrade
