Hi all,
I am using an elastoplastic plate (in plaxis 3D) and trying to control the axial and flexural capacity of the plate such that it approximates the behavior of a slurry wall. In the horizontal direction, due to the slurry wall joints, the flexural capacity is very limited while the axial force capacity is still decent. I tried the following:
- for vertical direction (direction 1), I calculate the yield stress and plastic section modulus as usual.
- for the horizontal direciton (direction 2), I calculate the yield stress (sigy,22) as usual, but I set the plastic section modulus (W22) to a very low number.
What i noticed that the maximum axial force in direction 2 (Np,2,eq) displayed to the right in the input window is very small (see attached capture), despite the high yield stress (sigy,22) that i provided. It turned out that its value is being affected by the value of W22. This is contradictory to the equations provided in the reference manual (Equations 383 and 358) which show that Np,2,eq is function of sigy,22 and d only.
Would someone please help with this?
Thank you
