Hello...
Is there any way that I can install PLAXIS 3D V20.
I wanted to use the software for my research BUT the upgraded V21 looks so much different and difficult to learn.
Dear Walid,
I think you are confusing two different products:
I have elaborated on this on the other post you made: https://communities.bentley.com/products/geotech-analysis/f/forum/236923/how-do-i-model-footing-to-measure-the-bearing-capacity-and-consolidation-using-plaxis-3d-v21
I can reassure you that PLAXIS 3D (finite element solution) has not changed much between V20 and V21 causing confusion with creating a simple model. You can read the changes in our Released Notes: https://communities.bentley.com/products/geotech-analysis/w/wiki/52258/plaxis-3d-ce-v21-00-01-release-notes
