Shaft and Base Capacity in Plaxis 2D
I am currently carrying out analysis on a large diameter pile in Plaxis 2D, with specific emphasis on the contribution of the base capacity. I understand that Plaxis 2D allows you to plot the full Fy reaction force against the displacement across the pile. I was curious to know if it is possible to get this Fy force from the shaft and the Fy force from the base separately, rather than as one total force, or what is the best method for obtaining the shaft and base capacity separately from a pile in Plaxis 2D.
Moreover, I was comparing the two soil constitutive models of the HSsmall model and the Mohr Coulomb model model. I was intrigued to know if the dilatancy cut-off option is also available in the Mohr Coulomb model Model, or if there is a reason why it is only an option in the HSsmall model.
John
Parents Reply Children
