dear all!
I want to get the output data (eg. bending moment M) at the same time interval (eg.1 day) during the simulated consolidation process of 300 days,how to implement this work?
Thank You.
Hi Xiong,
To view the bending moments with time, you can select a post-calc point on your structural element (https://communities.bentley.com/products/geotech-analysis/w/wiki/45998/selecting-points-for-curves) and then plot the node with time.
To get the correct time interval, you need to adjust the "Max number of steps stored" parameter in the Numerical control parameters of the Consolidation analysis, such that: "Interval" = Time interval / Max number of steps stored.
Dear Vasileios
Thank you for your prompt reply, I have carefully read the consolidation analysis in the manual and the link you sent me, but here's what I showed. It's not the same as yours, there is no bending moment M. If you don't mind, could you please send me the operation process or video?
Thank you very much for your answer!
Best wishes to you!
Are you certain that the node you have selected is a post-calc point on your structural element? I will repeat the part of the article concerning the steps necessary to select such point:
Answer Verified By: xiong qi
Sorry to reply so late
Thank you for your answer, the problem has been successfully solved according to your operation
My problem is that the structural nodes were selected before the calculation, and the source information of the nodes could not be
displayed in the post-processing. But the structural node selected in the post-processing solves this problem well.
thank you again
