I have two questions about the time dependent analyses in Plaxis
1. There is an option in "plastic" analyses to enter the time. But it also says it does not consider the soil consolidation. So what is this time input for? how is it being considered in the analyses?
2. For calculating the consolidation, can the "HS Small" model be used?
Cheers,
Farbod
Hi Farbod,Indeed a plastic calculation does not take time effects into account. But there are two exceptions: one is when we use the Soft Soil Creep model, and the other is when we use the viscoelastic behaviour for geogrids. For the latter case, you can also check November's coffee corner on the "mechanical behaviour of geosynthetics". You can find it here: event.on24.com/.../45EA334E1B5491C616B6374F8B81C028For your second question, the answer is yes. You can use the "HS Small" model for consolidation calculations.
Thanks Vasileios,
So when using the soft soil creep model, what does the plastic analysis do if it doesn't take the time into account?
Also does the time matter when calculating the steady state ground water level?
Thanks again,
Dear Farbod,
The phenomenon of soil creeping is directly linked to the time parameter. I would advise you to check our detailed article about the practical application of Soft Soil Creep model here: Practical application of the Soft Soil Creep model
Time property in a phase is not considered in a steady state groundwater flow calculation as we assume time to be infinitely long enough to reach a steady state condition. Note that pore pressures and deformations are not coupled when a Plastic analysis is used. That is the case only for the Fully coupled flow-deformation analysis.
You can find more details on this topic on our Reference manual.
Ah okay. So if I'm right, when you use the plastic analysis on SSC model, it only takes the secondary consolidation into account and not the primary consolidation.
Thanks Stefanos,
Cheers
Creep is a phenomenon that develops from the very first second of times. The SSC model does not differentiate the moment creep "steps in" because it is always there.
In SSC model the creep is there but the rate the model creeps is different at times. But that has to do with how the model is formulated so if you read the practical application it should be clear.
