Hi hello, can you help me with this case?
I want to analyze the long-term session, but the output said this, can you help to solve this issue?
thanks
Dear Celvin,
As the answer says above: you either have failure before the minimum pore pressures are reached, or alternatively you haven't specified enough load steps to reach the minimum pore pressure. Both you can easily check yourself.
With kind regards,
Dennis Waterman
If the problem is failure you should improve your design, if the problem is not enough load steps you should specify more load steps.
The problem may not be soil failure. It may be that you don't have all of the soil permeability values set properly.
