Settlement Calculation
Hello!
Im calculating settlement with Mohr Coulumb - Drained, and trying to recreate the following settlement behaviour:
I tried creating 2 different E-modulus by seperating the calculation into 2 phases:
First phase with a material with a higher E
Second phase with a material with a lower E
But the result was wierd, I only got a few millimiters of extra settlement in the second phase even tho I chose a really low E.
I also tried (using the same material for both phases) but using "calculation type: Consolidation (19 days)" for phase 1.
But the settlement was about 50% lower than "plastic calculation type" and the settlement behaviour looked diferent, heaving at the surface compared to just using plastic calculation:
I tried laborating more with just consolidation, tried different permeabilitys in the soil - which didnt effect the result much (Wierd)??), and I also tried changing the consolidation time, 10 and 1000 days. Then something also wierd happend:
The curves looked identically with the only difference that the x-axis-values was different. I was expecting the curve to have a different shape when using 1000 days.
Also, the settlement was a little bit lower when using 1000 days, which is also wierd??
But back to my original question, does anyone know how to model the soil behaviour to look more alike to my first graph?
Kind regards
Albin
