Hello
Im doing steady seepage analysis of Nuozhadu dam. It solve with plaxis without problem but when ı solve by python codes it give Error code 34 ( ultimate state not reached). But ı solved it. Why this problem occurs?
Thank you.
Dear Arife,
The PLAXIS Scripting interface is using the PLAXIS command line to communicate with the application. So, if running the model manually works fine, running the same commands via Python would give the same response.
I would compare the two command line history to see if there is anything different which can explain why the two models do not give the same result.My first guess would be the material definition.
If you need further assistance, please create a Service Request: https://apps.bentley.com/srmanager/ProductSupport
I created a service request. Thank you
