Hi everyone,
Is there a shortcut to see the total load carried by the piles in a piled raft foundation on Plaxis 3D?
Hello Batuhan,
Keep in mind the pile-raft works as a system altogether rather than individual components.
In any case, I would simply check the forces recorded in the interfaces added or if the piles are modelled as embedded beams directly the structural forces of each pile.
