Hi All
I have a model with many VALID custom connections. I am interested in removing some of them. Does anyone know how to do that?
Thanks!
Dear Omar,
You can select a custom connection with your mouse and hit the Delete button on the keyboard.
Otherwise, you can use the command line, for example:delete Connection_1
Note that we will work on including an option when you use the Right-Mouse Button combo box.
Thank you Stefanos! Truly appreciate your help and quick response!
