Hi
Was Plaxis tested for dissipation of negative porewater pressure (positive porewater pressure per Plaxis convention) for example via consolidation analysis? Are there any reference examples?
Thank you!
Dear Omar,
This can be modelled without a problem. Pretty much any undrained excavation deals with this problem when calculating the long term stability. Hence, it's a very common situation.
With kind regards,
Dennis Waterman
