Strange graph with soil test in the simulation of a UU triaxial test with the HS model
Hello everyone, I wanted to ask about the simulation of unconsolidated undrained triaxial tests in the "soil test" module: We entered a value of zero or close to zero in the "σ'xx" box (to simulate non-consolidation), then entering the other parameters, leaving the number of steps at 100 by default. The following graph was obtained with peaks, which interrupt the determination of the modulus of elasticity, however, increasing the number of steps, said peaks decrease but are still present in the curve.
What is the reason for the presence of these peaks? I would also greatly appreciate the observations or the error that I could be making in the configuration of the "UU triaxial test" when entering the data in the "soil test" module.
Or how could I find a solution?
