Hi there,
I am working on a comparison of a 1D wave propagation and Deepsoil, but I am seeing some large discrepancies. I am modeling a 15m thick soil column of clay (HS Small). The "bedrock" layer is a 1m thick linear elastic material wit vs = 550 m/s. The issues I am seeing are the following
1) Comparing input motion at the compliant base versus the recorded motion at points C and B, it looks quite different.
2) Comparison between DEEPSOIL and Plaxis:
My questions are:
1) Is it normal to see such a change in the input motion within the linear elastic layer? If no, what is the solution to fix this?2) Is it normal to see such a discrepancy between deepsoil response and Plaxis? If no, what are your recommendations to fix this? I have consulted with the reference manual and the examples provided here (https://communities.bentley.com/products/geotech-analysis/w/wiki/45528/one-dimensional-wave-propagation )and didn't see anywhere the answers I am looking for.
thank you
