Dear plaxis,
How can we model a rectangular barrette as an embedded beam row?
Hello Jamal,
You may use “User-defined” in Cross section type to define its geometry properties of an embedded beam (row in 2D). However, is often used for a pile row. You may check literature or calibrate before using it for a rectangular barrette.
You may refer to this article below to know pile modelling in a plane strain model: Pile modelling in a 2D plane strain model
