Find water flow through weep hole in retaining wall
Hi all,
I need to provide the diameter, length and distance of the weep hole in the retaining wall. For that reason I used flow analysis by providing a retaining wall and drain but water flow around the retaining wall not through the drain, Can anyone tell how to model to get the flow through the drain so that I will get the quantity of water flow through drain and from there will provide the dimensions of the weep hole.
Thanks.
Parents Reply Children
