Hi all,
I need to provide the diameter, length and distance of the weep hole in the retaining wall. For that reason I used flow analysis by providing a retaining wall and drain but water flow around the retaining wall not through the drain, Can anyone tell how to model to get the flow through the drain so that I will get the quantity of water flow through drain and from there will provide the dimensions of the weep hole.
Thanks.
Dear Nitharshan,
Because the water is flowing in the direction of the negative x-axis ....
With kind regards,
Dennis Waterman
Noted, thanks.
