To perform a relibility based analysis of a 3D slope model, I have created a 3D FE-Model in Plaxis 3D and in the next step I would like to couple this with an external software that changes the soil parameters and starts the safty analysis in Plaxis. I now want to have the external program read out the safety factor and for that, I need the corresponding command line in Plaxis Output. Can anyone tell me how I can query the SumMsf via the command line in the Output as I can do for example for the total displacement? I cannot find a ResultTypes for the Calcuation Information, but maybe there is anouther Output Object for that.
Dear Andra,
The object in PLAXIS Output is called Reached.
echo Phase_2.Reached.SumMsf # with Python is g_o.Phase_2.Reached.SumMsf.value
echo Step_32.Reached.SumMsf # with Python is g_o.Step_32.Reached.SumMsf.value
You can find more information on our Object reference under Help > Command reference menu.
