Hi, I am running Plaxis to obtain safety factor under Eurocode 7 DA1-C2 with HS model Undrain(A). The two different cohesion and friction angles for F2 layer and Plaxis responses are:(1) c'=0, φ=22 - Plaxis reminded of invalid material setting and failed to run.(2) c'=2, φ=25 - Plaxis can run calculations smoothly.
Kindly assist to advise the reasons. Thank you.
Dear Xiaolong Su,
It is difficult to say, as specific checks can result in an invalid definition.
Please submit a service request so that we can assist you with this specific question. Then, one of our support engineers can help you in detail: https://apps.bentley.com/srmanager/ProductSupport
