I am trying to export results from a model in the form of txt files (Report) for further post processing.
When I extract phase displacements or Sum phase displacements of Plates, the results come back without data (N/A).
See below the txt file outputs for the same phase:
..._ Table of total displacements.TXT
..._ Table of sum phase displacements.TXT (Same issue as with Phase displacements)
Am I missing something? Is there a (direct) workaround to extract the results I want?
Thank you in advance
Hello Vasili,
Which PLAXIS version are you using?
What is the command you are executing?
In my case with PLAXIS 2D 2023.1 it seems it works fine:
Hi Stefane,
I am using V22.
I am not extracting the results with a script in this case, but extracting them in .txt format with Report generator.
Thank you for clarifying it.
I could not reproduce it with PLAXIS 2D CONNECT Edition V22 that I tried, so I am not entirely sure about this one.
I cannot reproduce this issue with PLAXIS 2D 2023, either, but keep in mind that we improved the behaviour of the ΣPhase deformations with the new release (PLAXIS 2D 2023.1 Release notes).
If you want me to test this project, feel free to open a Case: https://bentleysystems.service-now.com/csp
That is unfortunate.
I checked with a few colleagues and they also seem to have the same problem in V22
I also checked and I get the same issue in V21:
I made a very simple model in V22 for me to double check the issue, so I opened a ticket in the link you sent and attached that model (reference number CS0016019).
Hello again,
My colleague is investigating, and he will come back to you as soon as possible.
