Plastic section modulus of a plate
Good Morning I am modeling hard rock tunnel and using plates as my shotcrete support. My plates are modeled as Elastoplastic and hence I need to input strength parameter W11 which I am confused regarding equation to be used. Manual indicate plastic section modulus to be bd2/6 in beam section of the manual, I however recall that plastic section modulus shall be bd2/4. My plates are mostly under compression with low bending moment induced.
