Is it possible to get run at the same time two lincenses of Plaxis3D with the same computer? or you need a computer for each lincense to run at the same time?
Thank you !
Hello Ana-Belen,
In general, the license consumption is recorded by the CONNECTION Client and only a single license is recorded when using PLAXIS Input and PLAXIS Output.
When you mean to "run two licenses of PLAXIS 3D", do you mean to run two PLAXIS Input applications?If you mean the above, then unfortunately no, PLAXIS can only run one instance of PLAXIS Input and calculation at a time.
Answer Verified By: Ana-Belen Martinez-Bacas
When you mean to "run two licenses of PLAXIS 3D", do you mean to run two PLAXIS Input applications? If you mean the above, then unfortunately no, PLAXIS can only run one instance of PLAXIS Input and calculation at a time.
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.
Flag this post as spam/abuse.
