Coefficient of consolidation parameter selection in MC model
Hi all,
In MC model, the excess PWP calculation is not correct and Cv term is calculated automatically in MC model based on input values Eoed (E and v') and k. Disregard these let's say I'm using MC model for the consolidation analysis without using any advanced soil models, I'm going to find the Cv value from the laboratory test (1-D consolidation test) which is provided in the SI report as shown below.
Here Cv was calculated based on different pressures. Since Cv is almost constant for the soil, my question is => which Cv value I can use for analysis in Plaxis for the consolidation analysis (does it based on the pressure I have used for the consolidation analysis) {If my applied pressure is 50kPa, then I will take the Cv for 50kPa in the laboratory test and apply in the analysis}?
Thanks.
Parents Reply Children
