Hi, I would like to determine the bearing capacity of mat foundation in PLAXIS 3D. I have tried two methods, one where I applied a surface displacement along the z axis (free along the x and y axis), the other where I applied a prescribed surface load along the z axis followed by a strength reduction phase (I would obtain the bearing capacity by multiplying surface load by MSF obtained). The results obtained are different.
Can i check what is the difference between both methods mathematically? Which method would be the correct method to determine the bearing capacity of a mat foundation? When applying the prescribed load, should I add a dummy element to model the mat foundation?
Thanks a lot Dennis!
Do you have any literature that you can share regarding (3)? I've seen that Hansen and DeBeer have proposed methods to determine the ultimate stress from Load-Settlement curves, and a third one based on Settlement/Base width = 10%, however I can't find the referenced articles.
Again, your assistance is much appreciated!
BR
Mohamad
