I am trying to export plots for structural elements. In one case i prefer to have a distribution plottype instead of deformation. Setting the plottype from python does result in a correct command in the plaxis command lines, however nothing happens. Only once i manually adjust the plottype, the command seems to work. g_o.Plots[-1].PlotType = "distribution".
Hi Niels,
I am missing some information before I start testing everything.
What is your product? PLAXIS 2D or PLAXIS 3D?
What version are you using? You can find that under Help > About menu.
What structural element are you interested in? Plate or something else?
I already tried with in PLAXIS 2D 2023.1 with a Plate element and it works fine:
(I promise I did not change it manually)
Answer Verified By: Niels Zee
Thanks for the quick response Stefanos! I am still working in Plaxis V22.02. So hopefully it's fixed in V23 then, i will update and check. But i trust you that it works. Thanks!
Hello again,
I just tried it with PLAXIS 2D V22.02 and it worked immediately for me.
So, perhaps we can check in more detail via a Case: https://bentleysystems.service-now.com/csp
Thanks, for some reason i can't seem to log onto the link you shared. Our accounts are coupled to a company SSO, do you have any idea how i could get on there?
