I am trying to export plots for structural elements. In one case i prefer to have a distribution plottype instead of deformation. Setting the plottype from python does result in a correct command in the plaxis command lines, however nothing happens. Only once i manually adjust the plottype, the command seems to work. g_o.Plots[-1].PlotType = "distribution".
On the page that opens, can you select the Bentley IMS? You will use your Bentley credentials to log in as the CONNECTION Client.
Please let me know if that works out.
The Bentley Identity Management Service (or Bentley IMS for short) is the web service (https://ims.bentley.com/) that manages the Bentley Cloud Services profiles (also called Bentley IMS accounts) that exist for the users in your organization, and also verifies the user's credentials when they sign in to Bentley through the CONNECTION Center (https://connect.bentley.com/).
Bentley IMS authentication lets users log in to a datasource using the credentials of their Bentley IMS account.
